Hi,
is there any issue with the gtir cylinder 4 ?
(the cylinder near distributor)
I got two engine, and both have the same compression on this one ! about 180psi on each others, and 90psi on the last one.
At the last check up, coolant was okay , oil too, so i espect something to do with valve or rockerarm ?
i did not rebuild my first engine with that compression due to the milage i decided to change the motor... but now, i got two block with the same prob.
Do someone already had this prob??
Thanks
Thanks
