Sirnixalot
ECU - NO
MAF - NO
Clutch - NO
Flywheel- NO
Exhaust manifold - can be made to...by those who are to cheap to get the proper thing made
Turbo elbow - see manifold comment
Head - can be made to fit but for what purpose is beyond me
Block - NO
Pistons - Yes
Rods - Can be made to but the bearings are inferior
Crank - fits yes but flywheel holes are smaller and requires the use of those inferior rod bearings as above
Oil pump - NO
Water pump - NO
Cams - NO
Head gasket - NO
Valve springs - NO
Ignition leads/plugwires - Jap spec RPS/S13 yes, S14/15 NO (S14/15 use a coil on plug distributorless ignition setup)
Distributor - NO (for one the S14/15 dont use a distributor and no the RPS/S13 one wont work)
Oil sump - NO
Fuel rail - NO
Cam gears/pulleys - yes
Rocker arm stopper - yes with modifications to the rocker cover
Rocker cover - S14/15 - NO (the big fuck off VTC controller on the intake cam should give that away), Jap spec RPS/S13 yes (require mounting point for throttle cable bracket to be fabricated on the RPS/S13 cover)
Accessory pulleys - NO
Engine mounts - you're kidding right? you werent really thinking of asking this? Incase you havent guessed it thats a NO!
Now that youve read this and taken offense to my sarcasm if i see any more "will this 200sx crap fit my R" and its listed in this thread i will lock that thread.
MAF - NO
Clutch - NO
Flywheel- NO
Block - NO
Pistons - Yes
Oil pump - NO
Water pump - NO
Cams - NO
Head gasket - NO
Valve springs - NO
Oil sump - NO
Fuel rail - NO
