3 bar map sensor
ashills
anyone thought or know if this can be done
using the an apexi AFC and standard ecu
change the maf for a 3 bar map sensor
antilag
doubt very much doubt it matewen i helped fit a 3 bar map sensor to a motec it had to b dialed in and the motec had to reconise it so i'd say no to this one but i could b wrong.no offence but if u wanna run 2 bar shouldnt u go down the fully mapable ecu wrote to b on the safeside????????
ashills
no its not that
just prefer map sensors to bloody MAF
and safes getting a 300zx one
but if thats the only option
Muppet
one problem with multi throttle as std with the pulsar is the poor map signal when there is no boost and hence why a maf is prefered. If you wanted a map sensor only you would probably be better going for a single throttle.
regards muppet
antilag
thats y we r mapping and setting the link up on my car using the maf instead of the map and aparently its gonna work a treat
