3" custom downpipe
turblio
Right, soon I shall be bolting on a 3" stainless steel downpipe with seperate
wastegate pipe that reflows back in the pipe a bit further down, it should
also have a flexi joint in it which will taper back to 2 1/2" for bolting direct to your decat (this may be 2and 3/4" but not sure at mo) what I am going to do is remove my hks and fit this then do a power run as I have just got a very accurate Dyno sheet of before (in other words the RR does not give you loads more power than some I know :wink: :roll: ) I will bolt the new pipe on and let you know the gain, and also wether you can up the boost without the usual det or turbo elbow heat and restriction problem ...
ps they will be around £360 quid inc vat maybe less
Frank
