i bought a 3/4 of engine (block without head) from a U.S. 200SX SR20DE Low port, i'm in the process right now, the crankshaft accept fine the rods... main journals are the same regarding to the specs of ACL main bearings the only difference between normal SR20 and GTIR SR20 main bearings are the oil holes, so i think its better to use the GTIR bearings...
about the rods, we are able to use any SR20 rods, rods journal and crank rod journals are the same wide and stroke the only difference are the bearings, so if you are going to use S13 or SR20DE rods you need to use 17mm bearings, if you are going to use Pauter X or GTIR oem rods you need to use the 19mm bearings, pistons are the same and stroke remain the same... flywheel adjust greate only thing is if you use 53J or 2J2 (SR20DE or S13 crank ) you need to use the specific flywheel bolts of they because GTIR crank use an specific wider bolts 54C flywheel bolts
good questions here are how the 53J Crank it's going to perform?
- less, same or better TORQUE? the 54C original crank more heavy than 53J crank but more heavy than 2J2 or Primeras P11 crank. (as i know heavy means torque.)
- a light crank will give us more HP? nice incresing RPM?
we will need to test and check... maybe an upgrade or downgrade? comments are apreciate... thanks in advance!
