Rimstock list the centre bore as 56.1 for the colt and 59.1 for the pulsar.
So the wheel may not go onto the hub unless you bore the centre out slightly. Try it before you buy.
Also find out what offset the wheels are, 40mm is standard. Most people with big rims run around 37-38mm (which means they sit further out) and 42mm would be too close in and require spacers.
