Can anyone help, when I start my Pulsar all the lights are dim and the ABS Light comes on and doesn't go off until I give the car a bit of a rev is it the Battery?
could be 1 of several things
but sounds like a dodgy earth connection somewhere (poss earth on your battery to the chassis)or your alternator more than likely
maybe worth having it tested ?
cheers
Jon
same happened to me. better check the tension on you alternater belt as it sounds as its going to come off. my tensioner bolt snaped and had the same fault.
