Any ideas on a price for this? just didn't want to try to find a car with Air Con to find out I can't use it anyway lolstumo said:AFAIK it's no longer available. you have to get a converter kit which is two valves and some oil that must be added to the system or the pump will die.
im local to you, and mines isnt working to greatFire & skill said:there is 'drop in' refrigerants available, they will run on the same mineral oil used in the R12 system. if you were local to me i'd have charged it for you. the R134a system uses a synthetic oil. see if you can get hold of a refrigeration engineer
