Hello guys,
I was wondering how come there still isnt a sticky thread with minimal rebuild parts requirements, etc etc as I see alot of posts asking about it. Maybe in the FAQ or something.
I am not familiar with engine rebuilds myself but I'm trying to gather as many parts as possible before sending the engine to the machine shop. I have a bad compression on the 2nd cylinder from the left (90 vs 160-165 on the 3 others) so I'm going for the big job.
Here are the parts I have so far:
10101-54C26 - Engine gasket kit
13500-54C00 - Oil pump cover
21010-54C00 - Water pump
13028-53J03 - Timing chain
13070-2J203 - Timing chain tensioner
30531-03E11 - Clutch fork
202-6005 - ARP connecting rod bolts
202-4303 - ARP head studs
NS1-HDSS - ACT Heavy duty pressure plate + street disc (rated 372lbs)
11044R302G - TOMEI SuperGrommet headgasket 88mm/1.2mm
I am also getting:
CP 86.5mm pistons (going oversize) + rings
Is there anything else I need (other than crank and main bearings because I obviously can't measure them before taking the whole thing apart). Are main bolts something that needs to be replaced when you rebuild? If so, should I get 10x 12293-54C00 (main bolts) and 10x 11058-53J00 (main bolt washers)
Thanks for your advice. I seek the smallest downtime possible
PS: if someone knowledgeable could write a sticky post with relevant info, I'm sure that it would help many of us!
I am also getting:
