N
Norfy
the problem i have is that the heaters wont go hot.
i have read other threads on this, and have identified that the motor is not moving the flap to allow the heat through.
i have moved my heater control panel into the glovebox, but have removed the hose which plugs in the back with its wiring because this would not reach.
i believe the problem is that i need the above hose/wiring to be plugged in for the heaters to operate, but i unfortunately binned it a while ago
what i wanna know is where the hose`s electrical connection plugs into so i can work on bridging it.
i have found a 2pin plug on the loom in the centre console (it has two wires-grey with red stripe, and green with yellow stripe)
any pics or info would be gratefully appreiceated
thanks
thanks
