OK OK OK!!!
After a year of my car being sat idle, i started it up for the first time, and now it doesnt want to :evil:
The car wants to run, its cranking over, but it will not catch
before you say SEARCH :roll: i already have
Heres the facts
Fuel pump is working, operated by switch in dash
Fault code comes up fine
there is fuel getting to the spray bar/injectors
there is a spark on all 4 plugs
timing has not been touched
Battery is brand new and fine
i have checked all earths, and regrounded if needed
an apexi safc is fitted, and not yet set up. although bought this second hand, and i knew it was working before hand. Does the safc hold its memory???
Maybe injectors blocked with sediment from the bottom of the fuel tank??
where is the crank position sensor? possibly disconnected??
Any other ideas?????
Ben
Heres the facts
Ben
