Anyone with 285mm HISPEC 4Pots
jaigtir
Put on hi spec brakes today to find it was a abugger to fit. The pads were so tight against the disc, you could barely turn the disc with your hand. After bleeding the brakes, found the car hardly stopped even with the pedal to the floor. Has any1 else found the problem, or is it just a bedding in stage? :?
memski
They do need a few bleeds to get right. Mine were well shit when I had them fitted, pedal just sank and no stoppers :shock: Work well given time.
