zia
the following is list of inspection to be carried out before assuming you have serious problem etc!!
1check engine oil level,oil condition,
2 crankcase ventilation
3check coolant level,and coolant system for leaks,and correct operation
4check battery condition,power,security of leads and connections,electrolyte level
5 remove spark plugs and check condition,gap,of correct heat range
6 remove dizzy cap check for internal and external faults,tracking,cracks look also for sign of water/ oil contamination
7check coil tower for cracks,tracking, poor connections
8 check ign amp for damage,cracks,broken loose pins.
9 check inlet system for vaccum leaks
10check breathing system for leaks oil,water contamination,sludge
11 check air filter for blockage.excessive dirt.
12 check exhaust system for leaks
13 check fuel system for perishing hoses,leaks, filter blockage check with hc meter if possible
14 check all known electrical connection for security and corrosion
15 check for carbon build up in inlet manifold pipes leading to it
if after these checks, the problem is still there have nice cup of tea and repeat until pissed off enough to take it to a garage :twisted:
zia
p.s i don,t think i,ve missed anything put feel free to add anything of value
zia
