Yes, that's how mine is set up.geetee said:Can you just run the new battery earth to a chassis earth somewhere in the boot, and chassis earth the original battery cable in the engine bay
Cheers fella i had a look at it today and it doesnt look to hard so i will give it a go after christmas, thanks for the info. 8)Mr GTiR said:5 meters of 4 gauge cable, 2 new battery connectors & connector block (can find all from your local ICE dealer).
Chop 1/2 meter off the 5 meters and use that for an earth. Might be worth putting black tape on it.
Feed 4 gauge through car and bulk head, connect it via connector block to exisiting battery wires. and on other end conncet to battery. Dead easy.
PM me if you need help doing it as your local to me
would a premiera one be better? will fitting a battery with more amps cause problems :?: ie burn things out? just wondering as im in the process of changing to a new battery and i just want the best.mattygti-r said:normal micra one
Aye same probs here when I needed a new bat few weeks ago. Can't remember what I went for in the end, but it did the jobSalmon_GTiR said:Damn small terminals... took me ages to find the right battery in Halfords!
