battry
Uncle Winnet
right ive got a new battry on my car but if i leave it 4 a few days it still goes flat battry has bean check and all is ok if i disconect it it holds it charg so there most be something on the car that is makeing it go flate any ideas what it could be or how to test to see what is doing this
john
Clifford alarm? (my old concpt 50 would drain montego in bout 5 days)
Has it always done this or just started?
Have you added anything electrical to your car?
Check your fuses as sometimes a blown one can make wigglys do funny things.
Do a current drain check and see if you (or an auto electrician) can trace it that way
Battery leakage current
It's along time since I did one, but you need a meter ( I used to have a gunsons multi meter)
You have to disconnect the battery +terminal and connect the red (+) lead from the meter to the battery+ terminal amd the black lead to the battery lead you disconnected. It will then show you the leakage current.
On a 40AH battery .5A is 3 days
On a 60AH battery .5A is 5 days
