All the numbers on the shells will be the same, so you cant work out what grade you need from them.
The number you need is on the end of the crank. You then work out what shells you need from that number, it tells you how to work out which ones you need in the workshop manual if my memory serves me right. If not Mike at MJP has the details on how to work out the ones you need.
