zee said:have you had a new exhuast fitted?
serks2 said:Well if its oli burning, then cant it be from having too much oil in the engine???
Fast Guy said:If you do have too much oil in, then you can be blowing it out of the sump into the breather system, then into the intake and be burning it off as smoke. (if your rings are worn)
Also if you haven't already, sort your gasket and it may run better. If it doesn't run better, find out why it's over fuelling and sort it.
