T
Timo
Well just of late ive started to get a small hesitation problem.
ie when given the car some beans change from 3rd quickly into 4 the engine will hesitate breifly when the throttle is put back down
also if say im in 4th at 4-5k in revs and i let of and re-aply the throttle it will hesitate
Ive done a fault code check which im getting code 55
also the car is over fueling slighty rich cloud of smoke can be seen when flooring it. had a friend follow me to see wot colour the smoke is. the result was slighty blue and smells badly of fuel. plus once hot everytime i let off theres a big flame.
could the probably be a dodgy lambda or maf?
Have done a compression test and all is perfect across all 4 wet and dry. driving temp is fine and oil pressure is fine
