chaged det sensor but problem is still there what can i do?
my car was showing a fault code 3.4 so i changed det sensor reset the codes but problem is still there
when i was changing the sensor i reliazed there was only one wire going to the sensor is that how it is sposed to be
do i have to see if the other end of the wire is connected to the ecu ?
is there any other way to reset the ecu apart from sorting it?
or is there anything else that i can do to get rid of the code 3.4?
please can someone help i dont want to waste anymore money.
thanks
hmmm
Reset the ecu by shorting the pins. Then take the car for a drive and see if the code shows after that.
The other end of the wire should be connected to the ECU (number 27, white wire I believe).
But wait for someone with more knowledge on the GTi-R to confirm or ammend my theory :wink:
I am having the same code show up as well and will be changing the sensor next week hopefully :D
Davey
There is only one wire, and a ground, or "screen", or whatever its called, which is earthed at the ecu IIRC.
It might be a wiring problem, if the code can't be cleared. Check the wire and any connectors in the wiring for the det sensor.
geetee
Run a new wire from the Det sensor all the way back to the ECU and have done with it.
GeeTee 8)
