smcnairn
just had a helix organic clutch fitted along with a new release bearing. Everything seems ok untill the clutch pedal is fully pressed to the floor and there is a metallic rubbing sound as if something is rubbing on the clutch cover fins. The biting point is also very close to the floor. It does go into gear and drives. Any suggestions to the problem will be appreciated. thanks.
