Hi,
Looking for some ideas on this one.
Replaced the seals in my clutch master cylinder a couple of weeks ago as it was p1ssing fluid on my shoe.
Since then it's fine from cold, but once the engine is up to temp the gear change gets crunchy and/or impossible.
I thought the bite was too low to the floor so adjusted it up a bit last weekend - but still when warm it does the same thing.
In 1st and stationary it feels like the clutch is dragging on and off - but it still takes the same inch or so of pedal travel to disengage the clutch and move off.
Going to do some investigation at the w/e so some pointers on what to look for would be welcome.
I'm thinking:
1. The clutch fluid is crap. I used DOT3 that had been open for a while. So will replace that with fresh DOT5.1
2. Clutch release fork has bent or broken... but then why only a problem when hot?
3. Gearbox oil needs changing.
4. Clutch slave cylinder has gone... but then why only a problem when hot?
5. Flywheel has highspots or clutch plate is warped. Being hot means they expand and are closer together?
Any other ideas?
Thanks
Graham
I'm thinking:
Any other ideas?
Thanks
Graham
