just loosen it say 3 full turns and see if its any better, it should bite around an inch from the floor
some people remove the bolt completely and adjust the master cylinder rod to its max which will then mean the clutch is overly adjusted, you must have freeplay at the fork end or release bearing may not fully dis-engage when clutch is hot
