Coin holder
How do U use a coin holder in the right of steering wheel (useless thing in most countries) ?
I want to make here an ignition panel, like this:
Very close size..
Can I move a mirror switch on the door, or in another place ?
c4cpa
it should be possible to move the mirror switch etc.. will just require a bit of customising !! most people seem to put a gauge of some description where the coin holder is, but i like your idea !!
MrMischief
Have a look on ebay - here's a Honda S2000 starter button - may fit a bit easier into that space :wink:
S2000 Button
or more here
The illuminated rim one looks cool - but sounds dodgy :shock: :lol:
Steve
N
Norfy
ive customised my coin holder to accept a push button starter.
took the coin holder out, turned upside down, removed fins inside it, and with a little trimming, got it to fit in upside down. which makes it perfect to accept a richbrook push starter and i also put a LED in the recess (now above the button)
worth a look if dont want a in-your-face switch panel :D
skiddusmarkus
I presume he wired the switch to the ABS relay/fuse/whatever it's called under the bonnet.If you remove it the ABS doesn't work.
what u think about me, dude ?
:twisted:
be sure :)
10A fuse in circuit
(20A switch)
