jiw said:Good thinking batman
i fitted a double core rad to mine the other week and had to chop one of the supports off for the fan motor on each fan as they where hitting the turbo and water hose
call me a numpty but wouldn' t that insulate it thereby stopping it from transfering heat properly :? the main problem being hot air from the turbo and not radiant heat from the engine/radShayneG said:Hmmm, I was advised to use heat resistant paint
Try this mate www.radtech.co.uk ,if you call them,you need to speak to Keith.boucherie said:Where abouts can i get hold of one of these, also can you provide info such as core sizes, and the CFM if you know it. I presume fitting is alot easier than installing a seperate FMIC as you are using the original mounts?
