You will need a compression test gauge,get your engine warm,but not too hot to work on,remove the fuse for the fuelpump,remove all the sparkplugs,screw the tester gauge into number 1 plug hole and turn the engine over a couple of times until you get a consistant reading.Do the same for the other 3 cylinders.
