turbodaily
does anyone have the nissan part numbers for std size crank bearings and thrust washers???
thanks
thanks
main bearings----12207-54c00 £8.70 each(pair)turbodaily said:does anyone have the nissan part numbers for std size crank bearings and thrust washers???
thanks
:search:turbodaily said:cheers lads, and the big ends/rod bearings?
You might as well put in ACL Racing bearings will not be much difference in price look under aclpreformance.com and then sr20det and it will show mains rods and thrust part numbers or just email ERic at ericspreformanceparts.com as he can supply them in what ever grade you need!turbodaily said:does anyone have the nissan part numbers for std size crank bearings and thrust washers???
thanks
pesh90 said::search:
I'll give you a clue [SIZE=+5]MAINTENACE SECTION[/SIZE] :roll:
