The more I look at my datalog and torque curves, the more I think my 2.5" elbow and exahust is limiting the engine. I always knew it would be less ideal than a drainpipe attached to the engine but I wanted to maintain some off-boost drivability. I have achieved this and the car is very smooth with the torque delivery like an NA V8 from 2500rpm. I believe there is a better compromise in there and as I need to take the exahust off to weld in a hole for my W/B lambda I thought I may as well just change it at the same time.
Reading around, the downpipe is a major restirction and that should really be 3". However, if that's 3", why not leave the rest of the system as 2.5"?
I've seen Scooby exhausts with a 4" downpipe that goes to a 3" system. This to me makes more sense than a 3" elbow and system. As I'm going for a custom build (done by the same bloke as did Jones_gtir), I may as well get exactly what I want and I'm not afraid to get something different.
0.Cheap Drivability, 3" downpipe with 3" to 2.5" section and the system and backbox the same.
1. Drivability, 3" downpipe, 3" to 2.75" to 2.5" system, existing 2.5" back box.
2. Top End and bring on the boost surge, 4" downpipe if pos, 3" system and back box.
3. Oh I don't know, do what everyone else does 3" downpipe and system etc... Baa
The way I see it, the biggest resistance (back pressure) is at the elbow where the gases are hottest, if you're exhaust is the same size after that then its just overkill. So if option 3 works well then option 2 or a variation on option 1 should work better overall.
I've got the RR this saturday which will be a good benchmark to show how restrictive or advantageous my current system is. I'll be counting my pennies and getting my order in after that so if nothing else it will have been useful experience but I only want to do it once.
Jim
Jim
