d2 fmic install
sandman-r
does anyone know exactly what's involved in installing a d2power fmic?
powerfreack
intercoolers are easy just read the instructions and you want go far wrong but if you get stuck just ask i am sure pepole will help
mad_matty
i was thinking off getting a d2 intercooler!
what do you think off it? have you had any problems or anything?
cheers!
You will need to move the washer bottle to the boot with these kits, And cut out a 3" hole in the two inner wings for the pipe work to go through, So it's not as easy as people tell you if you haven't got the right tools.
I've seen a couple of right bodge ups, To do a nice neat job you will need the right tools and a bit of patients.
Tool's will a good drill or hole cutter, Some sort of grinding tool to tidy up the rough edges, Some wire cutters and new conectors, A crimping tool or soldering iron and solder, Some new wire to run to the rear.
