nismo-400R
im thinking of getting a defi bf oil pressure gauge,just wanted to know is the sensor that comes with it a direct replacement for the stock one?ie will it screw straight in stock place
thanks
thanks
I think you may be getting mixed up with the water temp there, but i could be wrong.GTIR-LOZ said:you will need an adapter for the oil temp sensor so it can run both sensors as the ecu needs to know the oil temp as well
Yep - Oil temp not required by ECU - Defi sensor is 1/8" PT (PTFE tape on sensor prior to screwing in will work fine)Jonesy said:I think you may be getting mixed up with the water temp there, but i could be wrong.
