Absolute bastard bolt
Can't get the new sensor and bolt in..
Too akward!
I cant jus get it to catch the thread..
Need a alternative way..i been trying with extenders and knuckle socket.
Can I bypass it??
Is it reallyy needed
You could bypass it, or mount the sensor elsewhere... but that's really not a good idea. - The sensor is there to detect detonation and cut the engine before it grenades.
You can't clear the fault as long as the circuit is giving the wrong read-back voltage (although a remapped ECU probably has the option to ignore the input).
How about remove the downpipe (if you have arms like a gorilla and need to) to give more room to access from underneath. Possibly undo cat end of downpipe even and push it out of the way. I'm sure I've touched the det sensor from below with my hand.
I done it on a mates car from underneath used shit loads of different length extension bars on 1/4 drive inc uj fiddly but can be done
lying on the floor jack car up axle stands. Something tells me i removed drivers side wheel maybe just for space or to reach through past oil filter/cooler to hold extension i can not remember exactly
