another sunny
:twisted: still i have problems.....i fitted a new det sensor on sunday, after removing the oil cooler and the oil filter i could just get a socket on it....seized solid, i managed to pry the plug off and decided to re-site the det sensor ,this i did in a temporary position(near the base of the head-not ideal i know) after running a new longer cable i ran up the car(aftrer re-setting the fault code) only to find it running the same and after checking still a code 34.....really pissed off now all day that took.....fooking car.....if i could have found the matches.....
Any wayi thought maybe there is a problem with with the wire from the ecu...how do i check this or is there anything else i should check?
anyone!
anyone!
