jpward
Ok update to the "clunk rattle rattle"
Ran a compression test to night and to my horror :shock: test is as follows
#1, 160 psi
#2, 160 psi
#3, 160 psi
#4, 170 psi
So as you can see im gutted its not the pistons
:whoo: Not bad for a 40K 12yr engine!
So it apears to be the bottom end as everything else above it is ruled out,
What action should i take now :help:
Sump off for a look? or as ive never inspected a crank before only on my old engine leave it in to get the shells replaced and new ARP's fitted?
Ohh what else do i have to change seal/gasket wise? (Yes im being tight and only replacing what i have too)
Cheers JP
#1, 160 psi
#2, 160 psi
#3, 160 psi
#4, 170 psi
Cheers JP
