Hi all,
I just put my R into one piece again after a long time just standing in the garage.
My fuel pump stays on all the time when I turn the ignition switch to on. It should only pump fuel for a second to pressurise the line I think? I've tried an other fuel pump relay but that didn't solve the problem.
Engine is hard to start, will not start unless I apply some gas during cranking. When it starts it stays alive when I let the gas pedal off. Idle is somewhere between 2000 - 3000 rpm and it sounds like the engine "sneezes" every 2 or 3 seconds (backfires to the plenum??). Rpm drops 200 - 400 revs when the sneezing happens. I changed the cams to HKS 264's, is my cam timing wrong?
Fault code check shows 55, so nothing there.
I recorded a small sample with OBD scantech, I can e-mail it to someone if it helps. Just PM me your e-mail address.
