with the ignition turned off push a split pin into the connector bridging the two terminals.
turn ignition on and the fans should work. if they do then the problem will be the rad fan switch.
if they don't work then give fans their own 12v feed if they work then you have a vehicle supply problem. if they don't work with a seperate feed then the fan motor is how shall i say "no more"
car doesn't use fan switch, its controlled by the ecu on pin 9, ecu earths pin 9 to energise the relay which should complete the fan circuit and fan works!!
