GTI-R Nath
got fault code 21 today (primary ignition fault) and was needing some help figuring out what would cause it
i replaced these ignition parts about a year ago, and this is the first time if had the code,
roter arm
dizzy & dizzy cap
HT leads
ignition coil
spark plugs (correct heat & gap)
ignition coil
is the any other part in the ignition system that could cause this other than the parts iv replaced
thanks
roter arm
dizzy & dizzy cap
HT leads
ignition coil
ignition coil
thanks
