change of plans now guys not breaking its now running good work done by scott (warpspeed) needs a few wee loose ends tied up but its basicy as below but now avcr+safc are now disconnected and its running standard boost will need a little work done at the rear sills rest seem to be in decent shape! hopefully warpspeed will back up or correct what iv said pm me for pics dont know how too upload pics so will email you some!
hey guys got a gray h plate R for sale! only 500 mile from rebuild spec is as;
forge je pistons
HKS cams
forge front mount
HKS clutch ( well has HKS stamped on it)
cosworth head gasket
apexi avcr+safc
mongoose exhust 5in tip!
momo steering wheel if i remember right
hi spec callipers on front
leauge multispoke wheels
front and rear struts unsure of make
hardly any rust on shell,
bad bits; (NOW FIXED)
smokeing when warm (think its fueling problem either valve stem seals not done properly in build)
det sensor needs rewired
and the rear crank seal is leaking
thats all i can think of just now but 3K im lookinf for
comes with spaer box bonnet with vents and a few other bits and bobs!
cheers stew
forge je pistons
HKS cams
forge front mount
apexi avcr+safc
cheers stew
