Front mount piping
stuarty
Does anyone have any tips on how to get the piping for a front mount down behind the light area.......took out the washer bottle and was thinking about making that hole bigger for the pipe to go through......and do the same for the other side..................also if i disconnect the battery will this bugger the alarm??
N
Norfy
you got the hybrid setup????
if so you will have to enlarge the holes. draw round your silicone hose as a template and add about 5mm diameter to that
should be ok to disconnect the alarm, it has a battery backup.
stuarty
Yup its the hybrid one.... thats what i was thinking and just do the same with the other side at the battery ...i have taken the washer bottle out just thinking what to do wiith it......probably have to relocate the battery too????
