found this on the SR 20 forum, Some interesting info for all you guy's thinking about changing fuel pumps, With an easy to read graph ;-) :lol:
255 LPH is only a volume measurement. The problem with alot of pumps is that they can't supply the necessary flow along with the necessary fuel pressure (60+ PSI).
The 255 LPH Walbro is notorious for dropping fuel pressure at full load, and it does not accept voltage increase very well because it's just physically small.
A Z32 fuel pump on the other hand at 16V outputs alot of flow. Around the Skyline GT-R pumps at the same voltage. They are pretty easy to install as well, and readily available.
Aftermarket pumps like the A1000 are not too be left out of the equation, but understand that excessive flow through the system will lead to fuel warming as, at least on my 240, the return drops fuel right next to the baffled pick-up.
Seen here are the Skyline and Z32 pumps at various voltages.
To run this you can use the Kenne Bell Boost-A-Pump from SPL Parts (www.splparts.com)
