Sirnixalot
Usually after 280ft/lbs the gear box becomes a weak point as well as the 3/4th gear selector fork. Your shifting and throttle application becomes important above 280ft/lbs. You must shift smoothly and not just ram the lever into the gears. Also when you go back on the throttle after shifting you should try to apply the throttle gradually and not just stomp on it after you shift.
