Gearbox oil cooling possible??
Thor
Hello at all!
i had considered if it is possible to use a gearbox oil cooling system. Is anybody here who had tries that? I would happy if you can give me a pic or details where i could fit the pump and oil lines.
Thanks
Sascha
I know Rob had fittings put in his gearbox casing to allow a cooler to be fitted but never got round to it. I guess you'd want the feed to the pump somewhere near the bottom of the box and the returning cooled oil going back in somewhere along the oil gutter at the top of the gearbox.
What are you using the car for that the gear oil needs cooling?
Just found a picture of Tony Bardys Sunny Gti-R rally car gearbox, its not a standard box but you can see where (what i assume are the cooler connections) go in and out of the casing.
dencon
My PPG box has the inlet and outlet fittings,but I have plugs in these as I do not need a cooler for hillclimbs. I think these were fitted by Bernie.
