S.J
Heya Mates,
Not sure of you all remember, but i was having trouble with my headlights a while back, to put it blunt, they didn't work! haha
Lots of different possibilities, but none did the trick.
But i had an idea today, based on an old problem i had, but without the parts anymore i can't test my theory, so i'm hoping one of you lot will know.
You know how if you disconnect your hazard light switch from the front panel, your indicators don't work? well i found that out the hard way after hours of trying to figure out why they weren't working! but obviously when i re-connected my hazard light switch, the indicators worked again, Could the same apply to headlights if your rear numberplate lights are disconnected?
Reason being, when i stripped my car down to give it a full re-spray, i smoothed the boot over cause i think the indented boot plate looks shite, but obviously the rear numberplate lights aren't connected to anything now, but my lights worked fine before i stripped it down to respray, so i was hoping that if i connect some rear number plate lights back up to it, it would fix the headlight problem.
like i said tho, i dont have the lights anymore to test my theory, but anyone know whether this is the case?
cheers men/women
cheers men/women
