could be that it's air locked.take the rad cap off,turn it up to full heat on heater controls,then give it 5 mins of fast idle.it's better if you've someone to help as they can be used to top up the coolant system and tell you when it stops bubbling.nismoboy said:im not able to get any heat out of the heater, but then somtimes after long periods of driving i get warm air (not hot) just warm when i direct it on your feet and only when its in this position?
Cant be the stat as ive just chaged it. Any ideas
nice one, i`ll try greasing the spring and stuff first and see it that fixes it.Mr GTiR said:I had the exact same problem and got a new heater matrix second hand. Took the dash out and inspected my heater matrix. In the end the flap had come loose and as i turned the heaters to warm the rod that controls it was not moving the flap. All i did was grease up the springs and moving bits and it's been fine ever since. If your heater matrix is knackard then i have a spare you can have for free.
ive checked this and the rod is already in the towards me position so this cant be the problem.goeff pine said:could be air locked or could be the bottom heater flap is not opening behined the center consol just above the ecu on the passenger side is athin rod this opens the heater flap [door]see if this moves when the heater controls are turned on if not un clip the rod from the small plastic clip with a thin screwdriver then pull the rod towards you yuo should fell it moving and things should get hot this has solved my no heat problem for now :lol: having replaced the heater controls and found it made no differance
thats what i thought so i changed it to an uprated nismo one and the heater still dosent workFast Guy said:Also a faulty thermostat could cause similar problems.
