Can anyone suggest what to try next?
Car was ticking over on drive and cut out, tried to restart but was acting as if imobiliser had kicked in so locked it and reopened the car and but the fuel pump was not priming. Locked and reopened a few more times and started no probs. Thort nothing of it.
Took it round the block came home and switched to car off and now the problem is constant. Fuel pump is not priming on ignition.
Things tried so far.
fuses all ok
Relay by-passed but still nothing
Immobiliser by-passed but still nothing
Apart from delving into the loom is there anything else it could be?
No power appears to be getting to the relay so am thinking problem must be between ingnition and relay.
Relay was bypassed by sticking a wire between terminal numbers 3 and 5.
At a loss
fuses all ok
At a loss
