madcabbie
Hi guys, I have just bought a new steering wheel. It has 2 buttons on it, which can be pressed with your thumb without taking your hands off the wheel.
Hers a link to what it looks like --> http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=4554520186&rd=1&sspagename=STRK:MEWN:IT&rd=1
What I wanted to do was wire one up as the horn and the other as my Hi-Boost switch. The problem I am getting is 2 fold.
First problem is that the wire for the horn has constant power running to it, which I assume is right, but theres no earth wire. I assume I just connect the earth wire to the centre nut of the wheel.
The second problem is that the wires that run for the boost controller get wrapped around the wheel as you turn. This doesn't seem good, and sometimes gets jammed. It also pulled the connections aprt when it got jammed. Anyone know of another way to wire the boost controller upto the wheel?
I was thinking of cutting the main horn wire and connecting the boost controller to this. But then I wouldn't have a horn, unless I wire a switch somewhere else in the cabin.
Any suggestions will be appreciated.
