I
inFOCUS
When giving it full throttle the engine seems to stutter and hesitate at about 4-5000 rpm??????
Whereabouts do you get leaks on the intake side?Shalom said:also check:
- air leaks (intake side)
[go the trouble diagnosis manual section!]
yep found water in the end plug which isn't covered by the IC.smiff said:Water in the plugs.
Thanks, I'll try that this weekend.Shalom said:bean - usually anywhere theres a pipe thats clamped (like either side of the stock i/c) the manual says: pinch the blow-by hose (that short one near the throttle spring) to see if the engine speed rises - if so, you have an "intake air leak" - find and repair
