Ok this isnt really critical but its getting really annoying and i've only had the car back on the raod for about 4 days
since i put my car back together the car hesitates a bit when it is
started after the engine has been off for a while. Not necessary when its cold but just off for a while
When i took the box out i also took out the throttles and injectors
and fuel rail, got the injectors service and replaced the rubber
seals, etc, etc, replaced the throttles no worries. I also got the
starter checked out and it too was fine.
when i first got the car it always started first go, now when the
engine has been off for a while if takes about 3-4 cranks for it to
start and when it does its only doing about 200-400 revs (its sounds horrible)and then she comes to life.
If i turn her off and then on again it starts first go.
What could be wrong?
I think it has to do with fuel because other than that the car is
going fine, idles as it should, drives as it should and its not
sluggish, is there some sort of no-return valve in the fuel lines
because it seems that whilst the engine is off as if the fuel runs
back to the fuel filter??? (does that makes sense) so that when its
started there is no fuel in the fuel rail to start the car so it has
to wait for the pump to pump it in again.
Could there be air bubbles in the system and i need to bleed it. I
didnt think u needed to bleed the fuel system??
doesnt sound like elctrical problem, but more like a fuel problem
a little help? Has this happened to anyone?
Gino
[perhaps i should replace the fuel filter]
In da integra and civic
switching fo' lanes
wit da pedal down screeming out racin' aint a thing
Gino
switching fo' lanes
