nismo-400R
hi,think i might have a problem,my oil temp is goin high on idle like 90 or 95deg,ive just changed the oil temp sender unit as the metal bit was broke on the other one,and now this is happenin it was fine before didnt show over 80deg on idle,water temp gauge is showing ok doesnt overheat the fan is working,its not losing water or oil and the heaters are blowing hot inside,ive got a spec-r rad but had made out of copper not alloy,and a 16row oil cooler,im using siloklene 10w50 oil,car drives fine oil pressure is fine to,any ideas?thanks in advance
