davey red.r said:
tbh im quite happy with my rear pagid grooved disks,
to be bothered with that carryon paul:lol:
regards
davey;-)
I recently gave my read pads a freshen up and noticed they had a small protrusion engineered into the pad backing. This caused the piston to only press on a very small area of the pad and give very uneven wear to the inside pad and inside of the rear disk. Basically, only half the pad was touching the disk face and, it would seem full pressure from the caliper piston wasn't being applied either.
Anyway, I decided to grind off the small protrusion, as I wanted full pad and disk contact and, I was worried that the piston would be forced out on the pi$$ and damage the seal and bore.
The 5 minutes of work was well worth it as, the brakes are much better now. You can really feel the rears working and they really contribute to the overall braking effect, as well as keeping the car stable.
I use stock rear disks and Pagid 'fast road' pads currently for info.
Have a look at your pads and see if they are the same. You'll be able to tell by looking at the outer pad so, you won't even need to remove a wheel to see !
If the your pads do have the small protrusion, remove it and see how you feel about the brakes then...
Paul
