HKS Clutch
jpward
Right lads done a search couldnt find the info I require;
Basically I have a HKS clutch and about to do a rebuild so I would like to change the friction plate just to be sure but I can only see NISMO plates on greenlines site
Question is can I use one in the HKS? or does someone know where I can get a replacement that wont cost mega £* ?
Power figure 350-400 max not sure what Lbs level would be
jpward said:
Do you know what these would be rated to? :?
Its the clutch cover that determines how much torque a clutch will take not the friction plate :doh: :lol: :lol: :lol:
jpward
I know that but i stated i have a HKS one! and Rishi used to have one :der:
jpward
Cant seam to get Ian does anyone know where i can check different plates i can get and what ratings the cover for?
gtirx2
I have the same problem,i also want to keep my hks cover and find out which center plate to use.
Most center plates will fit with the hks cover as i am using a helix plate atm.I think a replacement hks 3 paddle center plate costs around £225 as where a helix is more around £160 like the rps plate.I don't have a clue as to which would be the best for more power as they are different materials and surface area sizes?
I have read somewhere that the hks clutch with paddle center can take 400bhp but that figure is no good as you need the torque rating so who knows?
All i want to know is like you which would be the best center plate to use with the hks cover if you are after 400+ horse with the same sort of torque in the future.
