Granite-GTiR
Hi all,
I've been having some problems with my R lately, its really not running good and i can't figure it out .
First problem
Right, had this problem for a while now, the car is really holding back, more so when it gets up to temp. When i put my foot down the car just don't go and the engine sounds abit groggy as if its running on three but not quite that bad. I have an AVCR hooked up and can see that its picking up boost, but the car hardly pulls. A few times whilst having this problem the cars ran fine, then its got up to temp and the problem starts again. Also the exhaust is popping alot and the car backfires from time to time.
I've changes the plugs, dizzy cap, rota arm, fuel filter, leads.
I'm having more fun driving a renault clio :doh: at the moment as i actually goes when i want it too!!!!!!
Second problem
Again, had this problem for a while. I'm getting some smoke (blue) appear from the exhaust when i back off/change gear. Not loads, but its really annoying me now. It doesn't happen all the time either, sometimes i'll be driving like a sunday driver change gear and i'll get smoke appear, whilst i can be driving the car hard and no smoke!!
I've replaced the turbo with one i got from 'Pulsarboby' (thanks again), so pretty sure its not that, done a compression test and got approx. 160 across all 4. Can't see any oil in the intercooler pipes.
Any ideas?
Cheers, Grant.
First problem
Second problem
Any ideas?
Cheers, Grant.
